No power to fuel pump!!!!!!!
Hey guys please help!!!! So I put a new exhaust and changed valve shims on my 929 recently and after putting it back together I had no spark. After shock wire connections and finding nothing I pulled the harness off and checked every wire. Well I ended up finding that my zener diode at ignition was readin 10 volts not 9 so I figured that was my problem. I order the new diode and I decided to use a 9volt battery to see if I could get her to start. NOPE!!!! After putting the harness back on the bike my fuel pump won’t prime. I hook it to battery and it primes so I know it’s good. I have no power going to it. All my relays are good. But I only have power going to one side of the the plug. And that’s only when I use a jumper wire on my engine start relay. I’m completely stupmped . PLEASE HELP
so what I did was hook up the pump to a battery and it started priming. As for the ground I wired it directly to a ground and nothing. I’m getting .078 volts to the fuel pump . I’m getting none to the fuel cut relay unless I have a jumper wire in the engine stop relay. Also, my powercommander was not getting power unless I had the engine cut relay jumped with a wire from the bigger red and white to black wires. The smaller red and white wire wire I’m getting no power to. I tried it with the powercommander out and still nothing .
I’m sorry I read that wrong. I thought you said how do I know my pump is working. I hooked each relay up to a bather and tested for contuity . They all work
I have my lean angle bypassed. I just put in the new zener diode and I’m getting 9volts like I’m supposed to. When I grounde my blinker wires out to my frame it sparks a little bit and then the dash lights up and the fan turns on. Also there is a black and white wire that goes fro engine stop relay to fuel cut, the injectors the sparks plugs and a couple other things but in the manual it connects all of theese and then goes to the ecu. But I don’t have a black and white wire in my ecu. I think my problem lies somewhere in the black and white wire . I have continuity through the wire but it’s the only wire that connects to all the components I’m having problem with. I’m loosing my mind man!!!
Yea, I saw that b/w wire and considered it to be a possibility. It's odd that you don't have one. Looking at the diagram the following all have commonality to that wire: coils/plugs, Pair Control Valve, Purge Control Valve, O2 Sensor, Fuel Cut Off Relay, Fuel Injectors and stop Engine Stop Relay.
In the absence of the b/w wire, I would check each one of these components to see if there is a common color combo and start there.
