No go
Old Apr 22, 2006 | 03:58 PM
tanner2's Avatar
Default No go
This spring I tried starting my bike and had a dead battery. Charged it up, left battery charger connected and when I tried starting the bike it turned over good, then smoke came out from under the windshield. The dash didnt work, so I got another one and that works now. Bike still wouldnt start and was told I probaly cooked the brain, so I got one of them still nothing. I dont have spark and the fuel injection doesnt turn on with the key switch. I pulled almost the entire wiring harness out of the bike with no burned wires. The dash inside wasnt burned either. Honda tech told me there is a tip switch buried up front somewhere that could be bad. Any help or direction would be greatly appreciated. It warm out and I wanna ride!!
Old Apr 22, 2006 | 04:12 PM
QuinC's Avatar
Default RE: No go
might also be your kickstand censor. but it does sound like the tip switch is doing it. what kind of bike do you have year etc..?
Old Apr 24, 2006 | 11:48 AM
tanner2's Avatar
Default RE: No go
The bike is a 2001 Honda CBR 929. The bike still turns over fine, so I dont think its the kickstand sensor. I thought it wouldnt let the bike turn over at all then, but could be wrong. I cant remember its been so long since I had the thing running. The problem with the tip sensor is that I cant find that either. I figured it would be behind the dash, but nothing yet. I have to get the tank off and get under that thing again.
Old Apr 27, 2006 | 03:30 PM
Black's Avatar
Default RE: No go
You've tried the simple things like plugs? Also maybe the battery isn't giving enough power to the starter? I'm stuck unless I can hear you try to start it. Could the smoke be some condensation from the exhaust? Were you inside or outside?
