New User needing help ASAP!!!!
Old Jul 13, 2012 | 12:42 PM
74demon's Avatar
Originally Posted by bebo_vi21
how do u jump it?
paper clip....
Old Jul 16, 2012 | 05:56 PM
bebo_vi21's Avatar
do i jump it between the two connectors on any wire or how specific does it have to b?
Old Jul 16, 2012 | 06:58 PM
74demon's Avatar
There is a specific connector for the codes. It only has 2 wires (green and brown) and is not plugged into anything. Jump the 2 wires together.
Old Jul 24, 2012 | 05:48 PM
bebo_vi21's Avatar
well it is three long flashes followed by four short flashes so seven flashes total.
Old Jul 24, 2012 | 06:03 PM
74demon's Avatar
Egcv/air intake door motor. code 34.
Left side of the bike under the seat. has, or should have, 2 cables on it. htev on exhaust, and one to the flapper in the air box. If you have those things removed, the motor needs to stay plugged in.
Old Jul 24, 2012 | 07:29 PM
bebo_vi21's Avatar
would that be the problem for the bike shutting off? cause i jus changed a sensor on the block that has a single cable that i believe to be the oil pressure sensor and the bike stayed on test drove it not to far and left it running after we turned it off and on off and on and the problem seemed like it gone ( I THINK!!) or i HOPE!!
Old Jul 24, 2012 | 07:31 PM
74demon's Avatar
That motor will not make the bike shut off.
Chabsy2k13
May 12, 2013 09:46 AM
jhag09
Apr 30, 2013 03:34 AM
Plead.5th
May 22, 2006 01:32 PM
