new bike question
Old Aug 23, 2005 | 01:05 PM
jarheadpsu's Avatar
Default new bike question
hey all, just bought my bike, a 2000 600 f4. It has 18,000 miles on it. It runs fine but I am not a mechanic, do i need to take it to Honda to do a quick inspection of it so they can make sure all is working properly. I need some feedback on this. thanks
Old Aug 23, 2005 | 08:38 PM
brancart1's Avatar
Default RE: new bike question
It certainly doesnt hurt. I would take it in and get it checked out cause when it comes down to riding a motorcycle i like to feel as safe as possible. I dont know exactly how much its gonna cost ya, but its better to be safe than sorry.
Old Aug 23, 2005 | 08:42 PM
jarheadpsu's Avatar
thanks man, will do
Old Aug 23, 2005 | 11:21 PM
slowpoke's Avatar
ORIGINAL: jarheadpsu
...I am not a mechanic...
You can bring it to a mechanic to check it out, but there are things you can and should learn to check yourself. Correct tire pressure, oil level, brake (and maybe clutch) fluid level, coolant level, throttle and clutch lever move smoothly, all lights and turn signals work, drive chain adjustment and lube, and battery level. Then as you get more advanced you can check spark plugs, air cleaner, brake pads, control cable adjustments, oil change, valve adjustment, carb synch, fuel filter, suspension adjustment and torque level of important bolts. Gee, if you can do all that, you'll hardly need a mechanic.
Old Aug 24, 2005 | 03:22 AM
Whippet Goode's Avatar
I agree with Slowpoke, if you perform routine checks, fixes, modifications yourself you'll know the job is done correctly & at a price you can live with. You will also see/know what is abnormal for your bike then enable the proper steps are followed to remedy the problem - including taking it to a dealer/other compedent mechanic.
Go to Amazon, Borders, etc and get a Clymer or Haynes shop manual for your bike. They cover every procedure in clear language with photos/illustrations. They also cite special tools when required to do a specific job. You either purchase said tool or take it to someone that has that special tool. Regardless you gain/retain knowledge about your bike and bikes in general, 'cuz this is probably not your last bike.
Good luck
Cheers
Old Aug 24, 2005 | 03:23 PM
brancart1's Avatar
Their right, as a matter of fact when you take the bike in to get looked at, you could always ask the mechanic to run over a short tutorial of what things to look out for, and even how to fix minor things your self. Read the owners manual if you have one, that will help you out alot. good luck.
Cbr_Guy322
Jan 14, 2011 05:26 PM
CSD10
Sep 12, 2009 03:07 AM
Macaco
Nov 4, 2008 04:09 PM
tillersluck1117
Mar 18, 2007 01:26 PM
jmabo205
Sep 2, 2005 10:43 AM
