need the name of a good paint stripper?
Old Feb 1, 2007 | 11:39 PM
youngrupe's Avatar
Default need the name of a good paint stripper?
looking for the name of a good paint stripper i can buy to strip my tank for paint.
thanks
Old Feb 2, 2007 | 12:06 AM
EPNF4i's Avatar
Default RE: need the name of a good paint stripper?
I have never use it myself but many people on this forum use a product called aircraft stripper.
Old Feb 2, 2007 | 08:28 PM
mikey1297's Avatar
+1 on aircraft stripper i have used it and it works well
Old Feb 3, 2007 | 02:25 AM
mdfirefighter's Avatar
yeah.... posted a picture of the aircraft stripper in your other thread in the detailing section. Here, incase you forgot: https://cbrforum.com/m_224973/tm.htm
MDFF
Old Feb 3, 2007 | 09:10 AM
Blue Fox's Avatar
Retired Moderator
Aircraft Stripper/Remover, whatever they call it. It has a picture of a aircraft on it, lol.
Really toxic stuff though (for breathing, skin, etc.) Make sure you take the proper precautions before using it.
Is your tank plastic though? I'm not sure if you can use that stuff on plastic. (CHECK FIRST!)
Hope that helps.
Old Feb 3, 2007 | 01:10 PM
OldFatGuy's Avatar
I've known a few strippers.... didn't have anything to do with paint though.
Old Feb 3, 2007 | 01:34 PM
Illushun's Avatar
I know them same strippers! They are better at polishing your tool. So I say no to strip and yes to polish!
Hahahaha.
I use a product called Strip-ease. You can get it at most local hardware stores. What's best about it, is that it comes in like a 24-30 oz container. Semi-liquid paste consistency. Although the noxious fumes will give ya slight buzz like the others, you can actually dilute this with water when doing your clean up and it won't leave that rust/remover residue like the others do. But then again, there is more prep work that gets done after removal anyway, so it don't really matter.
Make sure you wear like household cleaning rubber gloves. It absolutely burns like a bitch if you get it on any cut or if your hands are sweaty. Has a very easy clean up too. Cheap, like 7.00 bucks a bottle, and you only need 1 good layers. Use a hairdryer to heat it up and it will soften the paint a little before you put it on. Helps to reduce the excess need of more stripper and what not.
Old Feb 3, 2007 | 05:05 PM
TK954RR's Avatar
Jan 2009 ROTM
+1 more for airplane stripper
Old Feb 4, 2007 | 07:00 PM
06_F4i's Avatar
Zip Strip
its thick and will just bubble the paint right off
Existenz_is
Oct 31, 2015 05:04 AM
Petercdcn
Apr 9, 2013 10:13 AM
bgray
May 10, 2009 08:53 PM
youngrupe
Mar 4, 2007 09:39 PM
rizoss16
Aug 8, 2006 10:16 PM
