Need a lil help
Old Jun 14, 2008 | 08:00 PM
bkc4ever's Avatar
Default Need a lil help
Hi guys im new to the forum and i just bought a 93 honda cbr 600 f2 for a real cheap price. Ok now here is my problem,When i try to crank on my bike in choke it will stay on and i let it warm up a lil bit, but the minute i take it off choke it dies or if i try to rev it it dies.I just took off the gas tank and looked at the carbs and thehy looked clean, i change my spark plugs, but maybe my jets are clogged or the bowls of the carbs??? any suggestions?
Old Jun 14, 2008 | 08:54 PM
redzintimidator's Avatar
Default RE: Need a lil help
Yea, in the how to section there is a how to clean the carbs. it appears as though you need to clean your jets. I made a post on the bottom of the first page on how to do that. Clean the idle jet, and the main jet. do not worry about the upper part of the carb if cleaning the jets works.
but before you do that.,..is the fuel switch on?
Old Jun 14, 2008 | 10:08 PM
bkc4ever's Avatar
ok ill try that, and well if u could tell me which way to turn that switch because i dont have any fairings to tell me which way to turn it lol, but i have tried every way.
Old Jun 14, 2008 | 10:37 PM
woo545's Avatar
Yup...clogged jets. as for that right up...make sure you take a wire from a wirebrush and push it through the jet openings.
Old Jun 15, 2008 | 10:28 AM
bkc4ever's Avatar
ok thx im going to try to take the carbs out, it seems a lil difficult to take them completely off. Is there a write-up for that
Old Jun 15, 2008 | 02:45 PM
woo545's Avatar
Loosen the 4 screws on the bottom of the carb boots or whatever the rubber things are called...and pull (very difficult can rock forward first ...
Old Jun 15, 2008 | 05:03 PM
bkc4ever's Avatar
ok i just did it and now the bike doesnt crank in choke..... i added some fuel on the carbs directly and maybe i added to much so maybe its flooded i hope...
Old Jun 15, 2008 | 08:27 PM
bkc4ever's Avatar
ok i think i found my problem... does anybody have a picture of how the choke shaft should look like with the spring attached, mine came off while i was cleaning it and i just cant seem to figure out how it was put on.
