Need help trouble shooting GSX-R!!
Old Jan 31, 2008 | 03:06 PM
bassJAM's Avatar
Default Need help trouble shooting GSX-R!!
Here's the story:
One of my buddies has a 04 GSX-R 1000. He's not the best on regular maintenance, and one day when he decided to check the oil hefound that he was a quart low. So he added the oil and headed off to work. All of a sudden he heard this ticking sound, and it eventually gets soloud during his commute that he pulls over and calls someone to pick him and his bike up.
So I decided to drain his oil and filter it through a rag, and sure enough there are metal shavings in the oil. Soooo....what does this mean? Could this be any number of things or is it most likely a crank shaft bearing or something like that?
Old Jan 31, 2008 | 07:06 PM
Nauree's Avatar
Default RE: Need help trouble shooting GSX-R!!
GSXR
nuff said.
Old Jan 31, 2008 | 07:16 PM
bergs's Avatar
ORIGINAL: bassJAM
Shavings are normal. The size of the shavings matters.
Would you say they're shavings or small chunks?
Old Jan 31, 2008 | 10:43 PM
mauthman's Avatar
does the ticking increase with the rpm?? cuz if the oil was low or oldbefore then it could have bent a rod and when this ticking increases to really loud your effed. It happened to my car actually.. i know its different but a guy had it in his bike a few months ago on a post( there was a sound clip). He lost oil pressure somehow. I didn't know when it happened to my car so i had to replace the engine.. but if u catch it soon enough then its like a $600 dollar repair. It's just experience i've had... it could be lots of things tho.
Old Feb 1, 2008 | 04:03 AM
fishfryer527's Avatar
Not in any of my motors, I usually put one of those rare earth magnets on my drain plug before I change my oil, and I have never seen metal 'shavings'. My old vette had a bunch of plastic timing chain crap in the pan, but no metal in that 37 year old motor either.
Ticking sounds usually come from a top end problem like valve clatter, but my guess is a tranny situation if there was metal involved.
Side note: I raced a gsxr once when I had a 5.0 mustang, it was kicking my *** until a HUGE flame shot out of the pipe. I never saw a motor blow up before, my guess was it swallowed a valve...it was cool.
Old Feb 1, 2008 | 01:35 PM
Ty's Avatar
Ty
There are vacuum lines above the exhaust manifold/headers/whatever where it comes out of the motor that like to fly off on nearly every suzuki product ever made. They make a nice ticking sound when theycome loose.
Really, the only way to permanently fix it is to trade it in at the nearest authorized Honda dealer.
Old Feb 1, 2008 | 06:12 PM
Tacoma25's Avatar
This issue may not be able to be solved over the internet. When you say it was not maintained very well, that about sums it up. I bet he could not remember the last time he changed the oil either.The engine may haveto be torn down and inspected.
Old Feb 1, 2008 | 06:58 PM
bergs's Avatar
ORIGINAL: fishfryer527
Well my friend, how do you suppose engines wear out then?
Shavings exist in all used engine oil.
It's a fact...you can take it FWIW or not.
Like I said (but you prolly didn't read it all) "Shavings are normal. The size of the shavings matters."
Try putting your magnet on the drain plug for a half hour or so and see what you get.
Old Feb 2, 2008 | 04:16 AM
Visible shavings draining out or sitting in the pan are unheard of in a normal motor. Motors WEAR out, yes there may be 'solid'particles (as opposed to molecules or ions), but they are on the micron (tens of microns)level and on a magnet will feel like a sludge or fuzz (see link). Considering a motor may spin afew of billion times in its life, the loss of a visible speck of metal friction surface indicates failure, not wear. Imagine a few billion visible specks of metal, one for each normal rotation.
Almost all, if not all parts never even touch each other, they ride on a film of oil. They wear out in a very subtle fashion, but they fail catastrophically when they touch.
This link explains what I am saying, it may be old fashioned, but 30 years ago a lot of stuff was thought up because there weren't the high quality oils and alloys we have today.
http://w6rec.com/duane/bmw/trans/index.htm
Old Feb 2, 2008 | 09:02 AM
Jarrod Franklin's Avatar
shavings are normal!!!!!!!!!!!!!!!!! hahahahahahahahah omg
[align=left] [/align]
