Need help quick! I drained my battery.
Old 12-01-2011, 10:08 PM
LilRed F3's Avatar
Default Need help quick! I drained my battery.
I drained my battery at my house today...rookie mistake I know. Can I use a car
battery charger to charge it up? I tried to jump start the bike but it didn't work,
now the bike is parked down the block and I live up the block(literally up the
block as in a small hill).
Old 12-01-2011, 10:25 PM
nickp123's Avatar
yeah you can use a car charger to charge it....but if you tried to jump the bike with a running car theres a chance you may have fried your harness or some other stuff....
Sprock's Avatar
Typical car charger are 10 to 20 amps ------ too high for a bike
Ya can do it .....just take it off the charger when you figure there's enough charge
to start the bike ......
Best is to use a charger rated @ around 2 amps or less
Bike batteries are a lot smaller than car batteries
Hope when ya jump started it the motor was off in the other vehicle !
Old 12-01-2011, 10:27 PM
detroitcbr's Avatar
Yes you can use a car, leave the car off though, it has plenty of charge in the battery for the bike. Learning to roll start the bike is a valuable skill though, there's a good video on YouTube about it
Old 12-01-2011, 10:37 PM
LilRed F3's Avatar
By jump start I meant roll start, I misspoke.
Old 12-02-2011, 01:31 PM
gotcbr's Avatar
You can jump start w/ car jumper cables - as said above, just don't start the car.
Old 12-02-2011, 02:56 PM
LilRed F3's Avatar
Update 12/2/2011: I attempted to jump start the bike with the car off in the dark with poor lighting. Yes this is bad...the connections got crossed at the car side and I saw a spark on the positive side of the battery on the bike and then nothing...the ignition doesn't turn on, the light...nothing. I'm thinking the worst now. I checked all my fuses and none of them are blown. Could I have possibly fried the harness, electrical system, or just the battery itself? , I'm biting my nails here CBRF. I'm about to head to the parts store to pick up a new battery in hopes I just fried the battery and that is all. Please HELP!
Old 12-02-2011, 02:59 PM
74demon's Avatar
check the main fuse. that probably blew.
Old 12-02-2011, 04:53 PM
CJardine's Avatar
Track junkie & modaholic
and get a battery tender they are cheap and meant for bikes,
Old 12-02-2011, 10:14 PM
LilRed F3's Avatar
Update: 74demon, you were spot on, it was the main fuse. I really dodged a bullet on this one. Whew! Rookie mistake lesson learned, hahaha! I got real intimate with the bike. I took off the seat, tail section, and tank. I even checked and inspected my air cleaner, I'll be needing on soon. Thanks for all the help CBRF!
Quick Reply: Need help quick! I drained my battery.
