My dirtbike WILL NOT START! HELP!
i just purchased a 93 DR650 for 500 bucks and the damn engine WILL NOT START! its got spark, compression up the ying yang and i know its getting fuel cause i sprayed starter fluide right in the carb! plus i re-built the carb last night! i am out of ideas... any suggestions??
If you have fuel, propercompression and spark (at the right time) it will run. Is tthe spark plug wet? Sooty? If the spark plug is wet, it is not burning off the fuel, by either lack of spark or spark at the right time. If it is dry, it is burning it off or not getting any fuel.
the lobes on the cam are MINT and it wasnt showing any signes that the timing would be off when i took off the cover either.. cause the chain was snug and the lobes were MINT i orderd the service manual for a few days ago so i can do a number on the engine and get it runnen good.. still no luck on starting it thoe..[:@]
