Is my CBR600 Dead!!????
Old Jul 6, 2007 | 05:03 PM
gpz4jp's Avatar
Default Is my CBR600 Dead!!????
I have a nice 1993 CBR600F2 that has run perfect.....until yesterday. I pulled it out of the garge, put in the ignition key, turned it to the "on" position, the console lights went on and then I heard a "click" noise (from ignition switch....not sure) and everything went dead. I turn the key nowto run and nothing...NADA!!! No console lights, no starter button response....absolutely nothing. The bike has always started up perfectly with just a light touch on the starter so I'm not thinking battery. Has anyone else ever had this experience??? Any ideas on how I should proceed? I don't want to take to the dealer if the fix is something I can do. Don't have a voltage meter so I can't check electrical system. What else might it be? Cana deadignition switch do this on its own? Seems like it could to me but don't know for sure. Anything else that may need to be checked or replaced easily? Thanks forall the help!!!! What a bummer!!!
Send me an e-mail if you like also to gpz4jp@aol.com.
Old Jul 6, 2007 | 05:29 PM
Scrufdog's Avatar
Default RE: Is my CBR600 Dead!!????
could be the starter relay went out on it and took some fuses with it. Did you check the fuses?
Old Jul 6, 2007 | 06:46 PM
HAVOC's Avatar
^ +1 start with the easy stuff 1st before you freak out
Old Jul 6, 2007 | 09:34 PM
captain crash's Avatar
Definitely check on all the fuses, battery connections, and basic wiring connections before you even consider taking it to the dealer. From your description, my hunch is that it is a fuse/ fuses. Good luck.
Old Jul 6, 2007 | 11:16 PM
MojoWrangler's Avatar
My 900rr dropped a cell in the battery, no warning no problems beforehand, and did the exact same thing.
WhiteHawk
May 31, 2025 07:11 PM
jpopp88
Nov 14, 2022 12:34 PM
Thor19
Feb 21, 2019 05:16 PM
jsj
May 27, 2011 12:25 PM
gpz4jp
Jul 25, 2007 04:14 PM
