my bike overheats!
RE: my bike overheats!
Thanks for the reply. I checked the fan and found its not working.i pulled the fan and shop checked the fan and said it works so i changed the thermo switch. Still not coming on. Any ideas? I shut the bike down when the temp reaches about 245 degrees.The radiator is clean, but cleaned it more just for good measure.
ORIGINAL: bigjo
Thanks for the reply. I checked the fan and found its not working. i pulled the fan and shop checked the fan and said it works so i changed the thermo switch. Still not coming on. Any ideas? I shut the bike down when the temp reaches about 245 degrees.The radiator is clean, but cleaned it more just for good measure.
The fuse/relay is ok. I checked the wiring as far back I could follow it, I'm stumped. Want to avoid bringing it to the dealer. The thermo switch is the fan motor switch. That's what the dealer called it, so I used the same term. I thought I was using the wrong name. I appreciate any ideas.
Well if you have power through the relay, and you checked the wiring, and the fan is good, then it should be working. There's really nothing else. Do you have power to the fan when you are supposed to? If you do and the fan isn't starting, the dealer prolly told you the fan was good without checking it. Hook up test leads straight from the battery to the fan and see if it turns on. If not, get a fan. If so, keep looking for the electrical gremlins. They're in there somewhere.
my bike was doing the same when I got it. turned out the fan thermo switch was bad, so I just connected theplug straight
to ground and fan came on, ( that was temporary I 've since put in a toggle switch ),
BUT still ran hot.
I had checked the coolant and it had looked fine, untilI started sqeezing hoses at idlechecking for flow and
thermostat operation, it seems there was just enough coolant to cause a pocket under the cap, so I kept sqeezing the air
out and filling until it was completely full.
No problems since.
BUT still ran hot.
No problems since.
