mm size of rear axle nut on a 2006 600RR
Old Apr 14, 2006 | 08:54 PM
Frerice's Avatar
Default mm size of rear axle nut on a 2006 600RR
What is the size of the rear axle nut?
Correct me if I'm wrong, but I need to loosen that baby to do my chain adjustment. I understand there are chain adjustment screws, but don't I have to loosen the axle first.
TIA
Old Apr 15, 2006 | 12:12 AM
05Tribal's Avatar
Default RE: mm size of rear axle nut on a 2006 600RR
No offence bro but, [sm=icon_rtfm.gif]. Man, I love that smiley. Most of your maintenance questions will be in there. As far as the size of the nut, it is 32mm's.
Old Apr 15, 2006 | 05:51 AM
DThompson's Avatar
Yes you have to loosen the Axle bolt before adjusting the chain
Old Apr 15, 2006 | 10:30 AM
Frerice's Avatar
No offence taken, 'cause the nut size is NOT in the manual. I was pretty sure you had to loosen the axle nut, but wanted confirmation, so I threw that out there.
Thanks for your help.
Old Apr 15, 2006 | 01:21 PM
doncollins's Avatar
Retired Administrator
You have to be careful when reading the manuals. They usually list the thread size, not what size socket you'll need. I had to measure and buy the right size sockets for my axles and steering stem nut.
Old Apr 15, 2006 | 01:48 PM
05Tribal's Avatar
One thing to keep in mind for you guys and gals who haven’t had the change to collect the proper tools over the last 15 years of there "adult life", is that your 600's should have come with a tool bag and in that bag you should have the tool to loosen and tighten the rear axle nut. After you adjust the chain and tighten the nut good and tight, ride over to your local bike dealer and ask them to torque the nut down to specs. The torque for the rear axle nut is also listed in the user manual if can’t get to a Honda dealer.
Old Apr 15, 2006 | 06:34 PM
Frerice's Avatar
In the 2006 tool bag all you get is a 5mm allen wrench and the helmet lock cable. Everything else is sold separate now, Honda is making you buy your tools. I had to buy my pin spanners to adjust my rear preload.
astro929
Aug 1, 2011 10:04 PM
hondajunkie
May 28, 2010 02:54 PM
dave ls1
May 19, 2009 11:32 AM
WAR MACHINE
May 22, 2008 03:30 PM
kup125
Mar 26, 2006 09:02 PM
