Mixed Up Valves & Shims
Old Apr 4, 2012 | 07:57 PM
foxens's Avatar
Angry Mixed Up Valves & Shims
I think I know the answer to my question but I want to run it by the group. Long story short, all of my valves and shims got mixed up. I do not know which goes where, so how do I go about putting them back in there place?
Old Apr 4, 2012 | 08:32 PM
74demon's Avatar
Just put them in and measure them. Move them around accordingly...
Old Apr 4, 2012 | 09:50 PM
foxens's Avatar
When will I know if it is correct?
Old Apr 4, 2012 | 10:09 PM
74demon's Avatar
They will all be within spec.
Old Apr 4, 2012 | 10:32 PM
Project96's Avatar
What he said
Old Apr 4, 2012 | 11:08 PM
foxens's Avatar
I guess what I am driving at is, what are the specs, or where can I find them.
Old Apr 4, 2012 | 11:19 PM
74demon's Avatar
The valve specs are in the service manual. If you dont have one, download it. Idodirt has a great write up on valve adjustment....
Old Apr 4, 2012 | 11:20 PM
The valve clearance specifications are in the shop manual. Not knowing what bike you have makes it real difficult to tell you. I imagine you might find a link to a manual on the site if you search. You could also probably Google it to find out.
What you'll have to do is just install the shims anywhere since you don't know where they're supposed to go. Put the cams back in, tighten them down to specification Get the cam chain back on in the proper place and timed correctly. Then check all of your clearances/gaps to see what the clearances are. You may get some right, some may be too tight/close, and others may be too loose/wide. You'll have to determine from there how much it needs to change and then take it all apart and see if swapping any around will bring them back into specification.
Good luck... that's not a procedure that I'd like to have to do.
Old Apr 4, 2012 | 11:27 PM
foxens's Avatar
I have a 02 F4i, and thanks for the wishes I think going to need them.
Old Apr 5, 2012 | 11:08 AM
DonnyBrago's Avatar
That is a spectacular ***** up.
Just to make it worse, chances are that when you put the shims back in and tighten everything back up, some of clearances will be so tight they will be touching the camshaft, these cannot be measured so you will need to swap them over with a different shim and repeat the whole thing a few times before you are done.
Just a note:
DO NOT BREAK THE CAM COVERS, tighten down in the exact order listed in the service manual using a good torque wrench. If you mess that part up and break one of the covers you will need to buy a new cylinder head.
