Missing piece of Crankcase-WTF do I do???
Old 11-09-2008, 01:41 PM
madgreek's Avatar
Default RE: Missing piece of Crankcase-WTF do I do???
I sawafter I posted. Torque specs are on the 1st page of the clutch section [sm=smiley29.gif]I'm-a tar-ded. Thanks Pam.
  #22
Old 11-09-2008, 01:54 PM
Pamw's Avatar
ok..I looked closer at your photos....will be difficult to build that up even with JB and either using a helicoil or a timecert( would be the best choice if you decide to)to get to hold.....there are enough bolts around the case that the missing one "should not" be to much of an issue....plus it is on the top side of the case. repairthe damage to the actual sealing surface making sure it is dealy flat and ( I would get Hondabond HT instead of regular RTV...the HT is a a contact type cement and has much better sealing qualities) seal it up.
email me direct at pamw0001@yahoo.com.....if you want to arrange to talk live about this...would be glad to help
  #23
Old 11-09-2008, 02:02 PM
madgreek's Avatar
xxxxx
  #24
Old 11-09-2008, 02:09 PM
Pamw's Avatar
honda bond HT is white-ish
  #25
Old 11-09-2008, 02:17 PM
Pamw's Avatar
you can see the color of the sealer here on the stator cover
  #26
Old 11-11-2008, 06:18 AM
madgreek's Avatar
The dealership had hondabond ht ($15-wow!), but didn't have the starter idler gear thrust washer in stock (discussed above). It is part number 90401-MEE-000. It is a M 10x28x1 washer. I'm going to call up another dealership today for it. In the meantime, I was wondering if I could use a regular washer. I would assume if it's stainless steel (not chromed steel) or aluminum, then it should work, if it's the same size. Is this too big a risk, or do you think it will work? The dealer could have the washer in by the end of the week if I ordered yesterday.
  #27
Old 11-11-2008, 06:47 AM
Pamw's Avatar
unless you can machine a washer to the exact thickness...order the part
also it is probably hardened...(heat treated)
  #28
Old 11-11-2008, 07:22 AM
Northernfirepower's Avatar
Yeah, stick with stock and it looks like you should resurface that starter gear or whatever shown with some scotchbrite or emery cloth cause it looks a lil chewed up.
  #29
Old 11-11-2008, 11:17 AM
madgreek's Avatar
xxxxx
  #30
Old 11-14-2008, 02:28 AM
justasquid's Avatar
I realize you want to keep all the bolt heads the same.
but, you could always place a threaded studin that partial hole, jb weld it up and it would hold really well. then just get a nut a washer and tighten it down.
Quick Reply: Missing piece of Crankcase-WTF do I do???
