Lost all power!
Old Sep 12, 2008 | 08:49 PM
KRUSHER F3's Avatar
Default Lost all power!
I got a 1996 CBR 600 F3. Just rode it to work today, no problems. Got on it after I got home to go to store, turned on key, pushed start and it cranked right as usual. was backing out of the shed and BAM engine died, lights went out, lost ALL power!! Checked fuses at right fairing, all ok. Checked fuse at starter solenoid, ok also. Battery has 12.87 volts across terminals. nothing works or comes on when key is on. Any suggestions????
ADDITIONAL INFO:
Here's something weird: I charged battery, across the terminals (key off) it has 12.96 volts. Turn the key on no power to anything and voltage across battery goes to 0.10!
Old Sep 12, 2008 | 09:39 PM
fast1000f's Avatar
Default RE: Lost all power!
my dad had a similar problem turned out to be has ignition, mabye that helps. at least somthing to look at
Old Sep 12, 2008 | 10:29 PM
KRUSHER F3's Avatar
ORIGINAL: KRUSHER F3
ADDITIONAL INFO:
Took a wire and put it on positive terminal of battery, touched to starter side of relay and nothing. You can touch that same wire to the frame or to the negative post and it will barely even spark (about like a 9 volt transistor battery) the battery does have 12.96 volts. I took the test meter on ohms and checked the negative cable to ground and according to that it's connected.
Old Sep 13, 2008 | 04:19 AM
justasquid's Avatar
sounds like your battery is fried.
A few things to check. Make sure your cables are connected and not corroded. Pull the cables from the batter and clean them. Check to make sure your battery terminals are not loose or cracked. I would also run a second ground wire from your post to the chassis just to make sure your neg battery cables isnt broken inside.
Bring the battery to someplace like autozone and have them load test it. It may have 12.9 volts, but no amps. Sometimes, the battery will fail internally and short out internally for various reasons.
Old Sep 13, 2008 | 06:02 PM
KRUSHER F3's Avatar
ORIGINAL: justasquid
That's what a couple of other people told me so I just stopped on my way home from work and picked up a new one. Got it charging now. The battery was on it when I got it 2 years ago but don't know at that time how long it had been on there. Just glad it happened in my yard and not out on the road!
Old Sep 14, 2008 | 06:11 PM
KRUSHER F3's Avatar
Well it WAS the battery! Stopped and got a new one, put it in and everything worked!
Old Sep 15, 2008 | 12:45 AM
justasquid's Avatar
Its important that you now measure your volts at your battery with the bike running. You want to make sure its not overcharging it. If the rectifier goes out, it can overcharge the battery and ruin it. You'd hate to have a new battery suffer the same fate.
Old Sep 17, 2008 | 11:07 PM
KRUSHER F3's Avatar
Checked the voltage with it running about 12.96 at idle and 14 something at about 2000 RPM. rode it to work done good. Got about half way home that evening and the biuke shut down! The main fuse popped. put the spare fuse in saw smoke from right side of bike! pulled the fuse back out and the 3 wires from stator had gotten hot and melted. Guess the R/R went bad AGAIN!!
jasonchristopher
Jul 16, 2013 08:18 PM
asiddle
May 14, 2012 12:24 AM
marauderstyle
Aug 15, 2009 01:48 AM
xxxspawnxxx
Oct 22, 2008 08:27 AM
mufinkrakr
May 30, 2008 12:57 PM
