Led tail light wiring
Old Jan 23, 2024 | 04:35 PM
Keith33's Avatar
Default Led tail light wiring
What coloers go to what like what wires go to witch wires
Old Jan 25, 2024 | 03:07 PM
Scott91370's Avatar
You're going to have to be A LOT more specific.
What motorcycle are you working on?
What color wires are on the mototcycle wiring harness
What color wires are on the taillight?
Do oyu have and know how ot use a multimeter? This will save a lot of headaches by being able to see what wires have power when you turn the key on and when you activate the brakes.
Old Feb 2, 2024 | 07:06 AM
Old Feb 2, 2024 | 01:30 PM
dannoxyz's Avatar
Default DIY LED tail/brake light plug-n-play wiring installation
I'll put this here for future searches since this topic comes up often.
1. DO NOT hack up factory harness!!! It'll make troubleshooting much, much more difficult later. When you blow fuses constantly and lights don't work, verify first troubleshooting step is to unplug new light and plug back in factory unit. Then you can tell if problem is due to new lights themselves or with wiring. Can't plug back in factory lights if you've hacked up factory harness connector.
2. install factory OEM lighting connectors on aftermarket LED lights. Simple enough to just install factory connectors on aftermarket lights. Most Hondas use 2-wire or 3-wire HC050 connectors. Get them here and install them on aftermarket lights. https://www.corsa-technic.com/catego...ategory_id=278
3. simple plug-n-play aftermarket LED tail/brake light installation just like this!
Attached Thumbnails Led tail light wiring-hc050-blue.jpg   Led tail light wiring-hc050-orange.jpg   Led tail light wiring-factoryterminal.jpg   Led tail light wiring-factoryconnector2.jpg   Led tail light wiring-cbr600rr-frontturnsignalconnectors.jpg
Brandon929rr
Jul 13, 2017 06:51 PM
maximus3
Aug 30, 2008 07:49 PM
karmapolice991
May 8, 2008 08:29 PM
SnakeEyes237
May 24, 2007 12:43 PM
Stoic
May 10, 2007 08:26 PM
