key blank
Old 11-01-2013 | 05:15 PM
muppet1022's Avatar
Default key
hi guys just a quick one for you the 2003 defiantly has a chip I know this as I programed my own spares that I brought off ebay into my bike and that's a cbr 600 f4 2000 reg
Old 11-05-2013 | 10:13 AM
DonnyBrago's Avatar
Originally Posted by adapt63
Ah, once again Ive been given dodgy info
Not dodgy info, region specific info.
In the UK there IS a chip in the key. That is because your bike has a HISS immobiliser (look around key hole).
You'll need a key blank with transponder chip, get the key cut and then get the key programmed. If you have 2 keys, programming a new key is easy.
If you have 1 or 0 keys, it can be a massive PITA and expense.
Old 11-05-2013 | 02:16 PM
mikesx4911's Avatar
Well now I know as well for when I get a newer bike.
Old 11-06-2013 | 05:41 PM
adapt63's Avatar
ok I see. thanks for that.
i guees the blank i bought does not have chip. will see if it has insert for one. when i had my car key cut they had the transponders in store.
i will have to investigate more me thinks
Andy
Old 11-09-2013 | 05:03 AM
adapt63's Avatar
ok so I got the blank from china today and its really good quality! (most things are made there anyway now)
ok , so Im thinking how about I drill a little hole in the top and buy one of these id46 chips and stuck it in with some loctite?
KEY CHIP HONDA ID46 ID 46 BLANK NEW TRANSPONDER PREPROGAMMED IMMOBILISER | eBay
same thing surely?
many thanks in advance gents
Old 11-09-2013 | 10:38 AM
74demon's Avatar
I remember reading somewhere that if you tape the the old key with the chip in it to the ECU, you can use a non-chipped key to turn the ignition and start the bike.
Never needed to do this personally since we don't have HISS systems here.
Old 11-09-2013 | 11:54 AM
adapt63's Avatar
dont suppose your anywhere nr Berkshire? I will pay you to chip mine?
If not how did you do it?
Cheers
Old 11-13-2013 | 09:49 AM
jamestlester's Avatar
My dealer doesn't cut keys, and if he did he wouldn't do ebay keys. I got mine cut at an independent locksmith. It took a long time to find one that would cut them. Key was $3, cut was $10. He said they were tricky, and that's why most places won't cut them (walmart, etc.)
Old 11-14-2013 | 06:08 AM
adapt63's Avatar
i can get it cut....but its the cost of chipping....just been quoted £50!!!!
i can buy a house for that in the north!
Old 11-14-2013 | 06:03 PM
adapt63's Avatar
same thing surely?
so ive bought the above.....and it transpires the key blank has a space behind the blanking panels for a transponder! 99 pence! bargain. hopefully we can get the thing cut and programmed now. someone said a locksmith might do it failing that theres plenty of key cutting places about....
this is the blank i bought btw....
1PCS Blade Blank Key Motorcycle Honda CBR 600 F4i 929 954 1000 1100XX CB Black | eBay
