instaling -1 in the front
I got a new 15 tooth vortex sprocket and I am going to install it tomorrow while he puts on on his GSX-R 750,
is there anything special i should know about? I am pretty mechanically inclined but don't have much experience with bikes.
do i just need to loosen the back wheel, and take of the plastic cover over the sprocket? I am pretty sure i will need to move the rod that connects the shift lever to the transmission, is just taking the shifter lever off and swinging it out of the way the easiest way to do that?
do i need to grease the splines where the sprocket goes on the drive shaft?
does any one know the torque specs for the front sprocket and the back axle?
Nothing special about it, you don't need to remove the shift lever. Just take the plastic cover off and replace. Easy. If you have trouble theres a good writeup somewhere...I did mine not too long ago and was a quick job
Nero
F4i - Wanted
Jul 31, 2011 03:22 PM
bammerman
F3 For Sale / Trade
35
Aug 4, 2010 09:40 AM
TMAX
CBR1000F Wanted / Swap
Nov 18, 2009 12:41 PM
