Injectors
Old May 4, 2018 | 07:33 AM
cips007's Avatar
Default Injectors
Hi guys
Firstly I’d like to apologize for my other post regarding a knocking noise!
I’ve just had all my fairings off to trace the knocking and I’ve finally traced it to the injectors,I’ve read that they possibly tap,but mine are quite noticeably loud on warm up between 35-70ish. Can anyone confirm if this is normal please
Thanks
Old May 8, 2018 | 07:49 AM
cips007's Avatar
Can anyone tell me if this is ok/normal please
thanks
Old May 8, 2018 | 09:33 AM
CaBaRet's Avatar
Have you or previous owner had the valve clearances done
Old May 8, 2018 | 09:51 AM
cips007's Avatar
Hi
No they’ve not been done and currently at 23k
but it’s quiet at full operating temp and starts and runs perfectly?
Old May 8, 2018 | 10:10 AM
CaBaRet's Avatar
Not doubting you but never heard of injectors "knocking" , is it the primary or the secondary injectors that are doing this
Old May 8, 2018 | 10:15 AM
cips007's Avatar
I’m new to sportsbikes so am happy at any info/help 👍
i checked the cct for noise as that is the area I thought it’s coming from,but put my screwdriver on the injector stem closest to the cct and that’s where I’m hearing the tap/knocking?
Old May 8, 2018 | 10:28 AM
CaBaRet's Avatar
Righty-ho , yes that noise you will hear through a test of that kind, nothing to worry about there , but if it disappear's when warm that isnt the injectors , was it the garage that did the valve clearances or previous owner
Old May 8, 2018 | 10:38 AM
cips007's Avatar
I don’t think the clearances have been done on it yet,is this a valve issue?
ive been trying to look on the internet,but most valve issues/noise seem to be at operating temp,I can’t hear mine once full temp and no noise etc at any rev range at all
Old May 8, 2018 | 11:08 AM
CaBaRet's Avatar
Noises like this are common , when the bike gets to operating temp and the noise clears its because expansion has taken up the slack, if in doubt get someone to look at it, but dont be too concerned at present
Old May 8, 2018 | 11:19 AM
cips007's Avatar
Ok thank you,really appreciate your help,it’s in for its yearly mot test next week so will have a chat with the mechanic
Thanks
