ignition switch trouble
Old Apr 3, 2014 | 04:17 PM
Brillo67's Avatar
Registered Users
Default ignition switch trouble
Hello all,
I have to replace my right handle bar and got the throttle sleeve and cable hooked up. The trouble I am having, is when I go to close up the ignition switch. There is a large gap in the front of it where you can still see inside of it. I tried moving the scews around and that still did not help. Any suggestion on what to do or what I am doing wrong? I have attached pictures of it. the one with my hand holding it is the best of what that gap looks like when the screws are in
Thanks.
Attached Thumbnails ignition switch trouble-20140403_151109-1-.jpg   ignition switch trouble-20140403_151024-1-.jpg
Old Apr 4, 2014 | 07:58 AM
highwaypatrol's Avatar
There should be a hole in the handlebar that the bottom half of the switch engages with. It has a small peg on it that goes into the hole. When fitting the top part of the switch you may have to rotate the throttle slightly making sure the cable(s) holding part of the switch sit correctly in it. Hope you sort it but get back if you are still having problems.
Old Apr 4, 2014 | 06:27 PM
Brillo67's Avatar
Registered Users
Thanks! Gonna check it out now
Old Apr 4, 2014 | 07:23 PM
Brillo67's Avatar
Registered Users
Got it together! Thanks for the help
Old Apr 8, 2014 | 10:39 AM
Glad it worked out!
nutter
May 5, 2009 10:58 AM
new929
Mar 10, 2008 03:37 PM
tonyB11
Oct 26, 2007 06:44 PM
Ill_rider
May 10, 2006 11:51 PM
LikitySplit
Feb 20, 2006 04:06 PM
