Ignition Advancers
Old Aug 15, 2006 | 02:05 PM
rrasco's Avatar
Default Ignition Advancers
i was wondering what these were for...
http://www.motorcycleproshop.com/acc...nadvancers.asp
Old Aug 16, 2006 | 02:06 AM
gixxereater's Avatar
Default RE: Ignition Advancers
Those are the most popular ignition advancers for most bikes. They bump your timing. The time at which the ignition is fired in relationship to the piston rise in the cylinder. If it's say at 32 degrees before TDC stock, and you buy a +4 advancer, it will fire the ignition at 36 before TDC. It will give you more midrange and low end and supposedly clean up throttle response, at the expense of top end power. The gains/losses are probably minor at either end, but some people swear by them.
Old Aug 16, 2006 | 02:25 PM
DThompson's Avatar
Aren't ignition advancers for Carburated bikes,opposed to the Power Commander being for the FI bikes?
Just a question
Old Aug 16, 2006 | 05:09 PM
A power commander changes the fuel curve, adjusting for different exhaust's/intake work etc.
Old Aug 16, 2006 | 05:11 PM
Old Aug 21, 2006 | 08:21 PM
bindelsf2's Avatar
i bought a advancer and i love it.. i would recommend it!! plus its a cheap noticable upgrade..
Old Aug 22, 2006 | 04:58 PM
Err's Avatar
Err
bindel-did you notice a big difference??? was it worth the price???
Old Aug 22, 2006 | 07:05 PM
bindelsf2's Avatar
yeah i did especially on low end.it revs through the gears alot faster..
top end i really cant say to be honest.. i only had it up to 115 before i put it in and for the first time this week i topped 120 but it did seem to climb easier once i got on it pretty good.. but i also havent had it to the strip.sat we are going so i will post some times..
it was 53.99 from dennis kirk, so i feel the ends justified the means and it would be a wise purchase.
Old Sep 6, 2006 | 04:29 PM
jzcbr600's Avatar
They only offer a 2 degree for the f3. wil this be a noticable gain? How hard was the install? and will i need to get my bike jetted?
Thanks,
Jay
Old Sep 6, 2006 | 07:00 PM
bindelsf2's Avatar
the one that i got from dennis kirk
http://www.denniskirk.com/jsp/produc...09&mmyId=13834
said that it would fit f3's but it said ALT.....whatever that means...click on the picture and enlarge it and read the label.....
but no it was super easy to install.. you take off the timing cover (its in front of the clutch housing) same pattern as the gasket.... then loosen the bolt and remove the old one,insert new one...put the new gasket on and tighten the cover...thats it..no other modifications or adjustments needed
