Idle RPM
RE: Idle RPM
just thought also check for air leaks in your rubber boot on each side of the carb by spraying any accelerant(wd40, carb cleaner, eyther) onthe rubber boots, if you have an air leak the engine will breifly gain rpms as it burns off the accelerant if there is an air leak, which would cause your idle problem, if there is no leaks there will be no change in your rpms.let me know how you made out
