how easy to install pc III???
Old Feb 11, 2006 | 08:02 PM
Supersteve911's Avatar
Default how easy to install pc III???
Is it pretty self explanatory or am i going to have to take a lot of stuff off the bike? How long does it take.
Old Feb 11, 2006 | 10:26 PM
Deer_N_Beer's Avatar
Default RE: how easy to install pc III???
about 15 min. you should be able to get it all hooked up w/out taking the rear fairing off........its simple
Old Feb 12, 2006 | 05:34 PM
ampakes's Avatar
very simple. Just a matter of taking off the seats and a little plastic.
Old Feb 13, 2006 | 08:32 PM
Anubis's Avatar
Yeah Very Easy, I did have to remove my rear cowl to locate the wires because thats where i put the PC3, But 15-20 mins max.
Old Feb 14, 2006 | 01:14 AM
So its basically feed the wires up to the fron and then plug it into the plug in the side of the bike and then plug the one wire to the ground side of the battery. how muh plastics to I have to take off. I have a one seater.
Old Feb 14, 2006 | 02:30 AM
woogie's Avatar
I knocked it out in about 15 minutes this past weekend. All I had to take off was the seat and 1 piece of the left hand upper fairing (black piece covering the duct). I loosened the tank a little to get at the rubber skirt a little better, and to make it easier to feed the wire along the frame. The instructions are great, it's a piece of cake.
The only thing that I came across that was different from the instructions was the location of the unit itself. The 2005s (and I assume the 2006s) have a different undertray configuration than the directions. So, instead of all the way back by the tail light, mine had to go a little more forward. Fits fine, works fine.
Old Feb 16, 2006 | 06:50 AM
Anubis's Avatar
Its different for different bikes, I had to remove rear cowl, both seats, plastic tank cover and undo the 2 front bolts on the tank to hinge it up. Your F4i may require less? ?
joelacer
Sep 22, 2008 02:24 PM
vdubracer33
Sep 11, 2008 07:30 PM
Hashbrown1087
Aug 7, 2007 06:56 AM
de goose man
Mar 16, 2007 02:13 PM
kreush33
Jun 4, 2006 01:43 PM
