How do you fix a broken bar end? Literally broken
Old 09-15-2006 | 08:50 PM
sublyme's Avatar
Default How do you fix a broken bar end? Literally broken
When I bought my bike the bar end (slider thing) was broken but glued in, yes, nice, i know. I don't think it will just require buying new bar ends because well, it was broken off, the screw and the metal that it screws into from the handlebar basically broke right off. If I remove the grip will I be able to get to the last half of the metal sleeve thing and pull it with pliers or something and can i then replace it or what? Oh, and what actually is involved in this (how do i fix it?) tia
This is a 03 F4i btw.
Old 09-15-2006 | 11:40 PM
NWA's Avatar
NWA
Default RE: How do you fix a broken bar end? Literally broken
Your half of the bar end your are referring to is actually part of the clip on. You will need to drill out the broken off screw and buy a new one. The bar end is probably fine and reusable. Honda doesn't use the sleeve/rubber plug, or at least hasn't used them in a while.
Patience with the drill and you should be set with the cost of a mere screw. (Most honda techs have them stashed in their misc bins, since bar ends are always being bought or swapped out on new bikes. You might ask the techs before you spend your money at parts.)
Good luck
Keith
Old 09-16-2006 | 04:02 AM
zerochickenstrips's Avatar
Before you drill, if there is enough of the screw left, you can try grabbing it with some pliers and backing the screw out since there should be no pressure on it unless it was cross-threaded or bent. Aside from that, on the F4i, the bar end threads aren't part of the clip on. It is an insert, but not a rubber plug. there should be two holes on opposite sides of each other at the end of the clip-on (furthest away from center of bike). The insert has two "barbs" that clip into these holes. With alot of spray lube, a couple of small screwdrivers, and a lot of patience, you can push these "barbs" in and slip the insert out. Its a pretty long piece and they are usually stuck pretty solidly in the clip-ons thanks to time and water that has gotten into the ends. Use the screw to pull the insert out while you are pushing the barbs in.
Espguitarist33
07-13-2012 09:35 PM
DopeBoy239
F2 Tech
07-12-2010 09:38 PM
Cro
10-07-2008 01:53 AM
EA
07-15-2008 01:58 AM
