how do you clean carburators?
Old Apr 11, 2010 | 06:43 PM
cadillac curry's Avatar
Default how do you clean carburators?
some how when i turn on the gas and crank my cbr 600 f2, the spark plugs are automatically wet and the last time i cranked it, gas spit out the exhaust pipe!!!! do i need to clean the carburators?
Old Apr 12, 2010 | 02:45 PM
dyracuse's Avatar
Probably, sounds like your floats are sticky, so take care of what's associated with the floats, and might as well do everything else on such an old bike while you're in there.
Old Apr 12, 2010 | 03:33 PM
james_hale2's Avatar
yes. it sounds like they definately need cleaned. turn your fuel off, pull the carbs(do not change any adjustments), and pull the bowls off the bottom. once off you'll see the needle valves. the main is usually held in by the float(this is most likely your problem) and the float comes off by pulling out the pin. then the secondary needle is attached to the throttle somehow and both seats come off with a flat tip screwdriver. now this is all just carbs in general yours may vary from this in certain areas. once broken down you can use spray cleaner but i preffer the carb dip. it looks like a paint can with a strainer in it. take off the bowl gasket and any other rubber yours might have and dip it for however long that brand can says to and it should look shiny and new when you pull it out. now you can see if there is still any trash and scrub out with a qtip or pipe cleaner. after that (you dont have to) I resoak the carb again. then i rinse it all with gas and reassemble. yours i would pull the plugs and leave the fuel off and crank over for 30 sec or so to blow all the exess fuel out first.(before you try starting again i mean). whew long post sorry.
Old Apr 12, 2010 | 03:45 PM
if that fixes the prob you'll also need to do this after cleaning https://cbrforum.com/forum/how-mechanical-40/. good luck and keep us posted.
Old Apr 12, 2010 | 08:21 PM
aright well thanks for all the posts fellas. this looks like the most complicated thing I have had to mess with so far, I will let you all know how it turns out.
itgbudeev
Sep 15, 2008 03:03 PM
TennesseeCBRF2
May 11, 2007 03:23 AM
captain crash
Apr 24, 2007 03:02 AM
