hot rectifier
Old Jul 28, 2011 | 11:26 AM
graygeezer's Avatar
Default hot rectifier
I have a '94 600f2. Is it normal for the rectifier get hot while the bike is running?
I had the side covers off while finalizing the carb adjustments and took the bike for a spin.
When I got off the bike I could feel the heat coming off the rectifier, even the frame was hot where it's mounted! The battery seems to be fully charged, I didn't check it with a voltmeter though, the bike cranks right up so I figured it's alright. Any thoughts?
Old Jul 28, 2011 | 12:15 PM
gotcbr's Avatar
Originally Posted by graygeezer
...Is it normal for the rectifier get hot while the bike is running?...
Yes, it is normal. However, as a R/R gets older, it dissipates heat less. At a point, failure can result.
Old Jul 28, 2011 | 04:28 PM
MadHattr059's Avatar
+1 to Gotcbr
Just dealt with the issue on my 98F3.
They are designed to shead heat through the frame.
Check your connector. If it looks clean, you're fine.
If it looks like any of the connections are burnt
I'd start looking for a replacement.
Hopefully you aren't there, but take a peek to be sure.
Ern
Old Jul 28, 2011 | 05:09 PM
splash's Avatar
I just replaced the R/R on my '93 CBR 900. I've always had heating issues with the bike. every once in a while after stopping during a long ride it would not start again until it cooled off. recently it has been getting worse to the point where it was not running properly after a 1/2 hour on the road. after replacing it runs fine again. easy to replace. unscrew and unplug. note that Honda updated the part. it now has a heatsink to provide better cooling. updated part # 31600-MV4-0010
Old Jul 31, 2011 | 02:31 AM
DagonRais's Avatar
Mine g
Old Jul 31, 2011 | 02:33 AM
DagonRais's Avatar
Mine got a little hot one day and partially melted the plug... Once that happens the connections get worse and worse so I pulled the plug cut off the old connecttor and put some new one on and works just fine. No need to buy a new rr
Tremar
Feb 13, 2011 11:01 AM
cbrsingleside
Apr 28, 2010 08:55 PM
rkgjr1981
F2 Tech
Apr 13, 2010 11:46 PM
falieson
Jan 22, 2010 12:40 AM
Junior
Aug 27, 2006 01:25 PM
