Hooking up an IT tail light
So I just picked up a 04 integrated taillight and im trying to connect it to my wiring harness. I have a 97 that was a racing bike so the guy had all the wires dangling.
This is whats on my bike-
![Name: afeafe.jpg
Size: 65.9 KB](https://cbrforum.com/forum/attachments/general-tech-9/39953d1501275217-hooking-up-tail-light-afeafe.jpg)
![Name: adf.jpg
Size: 75.8 KB](https://cbrforum.com/forum/attachments/general-tech-9/39954d1501275217-hooking-up-tail-light-adf.jpg)
This is the integrated taillight
![Name: eafe.jpg
Size: 62.2 KB](https://cbrforum.com/forum/attachments/general-tech-9/39955d1501275217-hooking-up-tail-light-eafe.jpg)
![Name: fe.jpg
Size: 55.0 KB](https://cbrforum.com/forum/attachments/general-tech-9/39956d1501275217-hooking-up-tail-light-fe.jpg)
Can anyone tell me what wires hook up to what? the taillight has 5 wires and my bike has like 8.
![Name: afeafe.jpg
![Name: adf.jpg
![Name: eafe.jpg
![Name: fe.jpg
So Im gonna assume that its a 600rr????
*Disclaimer* I have a 600 F4
bike side wiring
blue - Right turn
orange - Left turn
green - ground
green /yellow and black /red are your tail and brake lights.
you need to figure that out yourself but it should not be too difficult.
tail light side
the two yellows are the turn. you need to figure that one out.
green /ground
red and black? They are your tail and brake lights. again on you to figure out.
bike side wiring
blue - Right turn
orange - Left turn
green - ground
tail light side
green /ground
You said F3, right?
Here's the key...
light blue is right turn
orange is left turn
brown is the tail/liscense light
green/yellow is the brake light
solid green is the ground
if you use the green (ground) and the brown (positive, always on) as tests on the
tail you're installing, you can (with the key ON) check each wire to see which is
which. I'm betting that CJ is right about the yellows bing the two turn lights and the
red/black being the brake/tail lights. hook the bikes green to the IT's green and then
use the bike's brown wire to each in turn, to see what lights up, marking them as you go.
Good luck, Ern
Here's the key...
orange is left turn
Good luck, Ern
some parts for sale.. tail cowl, tail light w/ mounting bracket, gauges, red frame sliders must sell
cannon
08-11-2007 07:58 AM
tutman6
04-01-2006 02:47 PM
