Honda F3
Old Jul 29, 2008 | 06:57 AM
Bax2u's Avatar
Default Honda F3
Hey, im new to this site, quick question, I have a 1998 Honda CBR F3 that is giving me some trouble. Its got a hard time starting, i've cleaned the carbs, and gas lines, new battery, checked the timing, replaced plugs, checked all vacume lines for clogs, changed sparked plugs. If i finally do get it over and i take her out it only lasts 15 min before it dies on me. some times i can bum start it or boost it but it doesnt last. Any suggestions would be appreciated. Thanks.
Old Jul 29, 2008 | 10:51 AM
Mstngdrew232's Avatar
Default RE: Honda F3
Have you drained the gas tank and put new gas in it?
Old Jul 29, 2008 | 01:20 PM
marc0011's Avatar
this is my 4th time trying... do a load test on the battery. Sounds li.k.e bike is dying because of there being low voltage in the electrical system. Also check your regulator/rectifier R/R . There is a thread on how to do this... I will put it up as soon as I find it.
Old Jul 29, 2008 | 01:32 PM
dusterdude's Avatar
is the choke choking?mine will not start cold without the choke.
Old Jul 29, 2008 | 07:29 PM
justasquid's Avatar
I would check to make sure your fuel petcock is not plugged. Pull the line from your tank and open the petcock to see if fuel runs out. It should be a fairly good stream of fuel, not a trickle.
Also, next time it wont start, pull the plug on the bottom of carbs float bowls. (should just be a screw) and see how much fuel runs out. This should tell you if your getting gas to your carbs.
Old Jul 29, 2008 | 11:35 PM
marc0011's Avatar
Here are the links I was talking about.
Flow Chart
Performing Tests
Jnothem
Oct 18, 2011 02:10 PM
MARTINEZ
Apr 7, 2008 12:23 PM
