Honda cbr600rr 2011 turned off
Old Oct 6, 2023 | 07:37 PM
jonnyfox9's Avatar
Default Honda cbr600rr 2011 turned off
2011 Honda cbr600rr turned off while at the light. pulling up to the like it jerked a small bit. Will not turn back on. Pulled to the side and tried bump starting, bought a battery. Still no start. Im thinking stator but might be a fuel idk where to start. The lights and everything turns, it chugs normally but wont turn over.
Old Oct 7, 2023 | 09:04 AM
rockpool's Avatar
If you have a charged battery, it doesn't matter if the stator is good or not - it will still run (for a time).
You need to stop guessing and start testing - fuel, fire and air - start there. There's usually a good troubleshooting guide at the back of every service manual.
Are you sure it's simply not out of gas?
Old Oct 12, 2023 | 02:56 PM
jonnyfox9's Avatar
I did the carb cleaner test in the air intake and it started up. And stayed started after. The next day it started too. The day after it wont start with carb cleaner. Im testing the fuel pressure next. Just finished testing the electrical system. Everything is fine electronically. It back fired but did not start.
also I hear the fuel pump start up
Old Oct 14, 2023 | 09:42 PM
jonnyfox9's Avatar
Fuel pressure is fine, injectors are fine checking the spark plugs next. But confused y it started again if it is spark plugs
Old Oct 15, 2023 | 07:42 PM
jonnyfox9's Avatar
I checked spark and receiving no spark, the plugs look fine. I have no clue where to go next.
someone plz help
Old Oct 18, 2023 | 02:56 PM
dannoxyz's Avatar
If ECU detects, rightly or wrongly, that there's safety issue, it will kill spark.
Kinda like when you put kickstand down with engine running, it kills spark.
Measure safety switches at ECU connector. Need to measure at ECU connector because wiring in between switches and ECU may be broken.
meyerlansky
Sep 14, 2022 06:01 AM
Larry Russell
Sep 19, 2015 08:44 AM
eXtremeFairings.com
eXtremeFairings.com
Mar 9, 2012 04:57 PM
cajunmesa
Sep 30, 2005 12:19 PM
