high rpm bog
Old Mar 20, 2007 | 12:54 AM
hooliganRR's Avatar
Default high rpm bog
Hey i just got a 99 CBR900RR and when i test drove it i really didn't get on it at all and it all seemed ok.. after buying it however lol i finally got on it and soon realized that when it try and get on it... it bog's down and has trouble climbing up. if i slowly get on the throttle it is ok. i took apart the carb and cleaned the jets and made sure there were no sediments in the bowl, then i removed the spark plugs they were a tanish color so i don't presume it's running rich (which at high rpms would prolly be ok anyway) my last thought is the valves... i've yet to do a compression test since.. well i don't have a compression tester =p
if anyone has any ideas of what could be the case, it would really be appreciated. thanks alot!
-Roi
Old Mar 20, 2007 | 04:28 AM
pacemaker's Avatar
Default RE: high rpm bog
How far up the RPM scale do you go? they do have a rev limiter, makes it feel like its bogging down (which it is)
Old Apr 2, 2007 | 01:10 AM
hooliganRR's Avatar
it happens around 6k rpms till about 9k then after that it clears up and is fine
Old Apr 2, 2007 | 08:21 PM
mccannf3's Avatar
How did your air filter look? Dirty/Clogged?
Old Apr 2, 2007 | 08:32 PM
xtremef4i's Avatar
In my experience working on ATVs I have seen several similar issues as yours. After replacing the fuel pump the problem was cured. You might try to test the fuel pump and make sure it is in spec. Also make sure that your needle valves and seats were good in each carb
Old Apr 2, 2007 | 09:01 PM
Joker_114th's Avatar
Had the same same prob on my FZR,found out it was the emulsion tubes worn out........to much fuel=bog for me.....
pipedcbr
Oct 24, 2010 10:20 PM
LC1
Dec 27, 2007 02:33 PM
Blade Drifter
Oct 29, 2007 02:27 PM
cbr_in_my_dreams
Dec 20, 2005 03:24 AM
