High engine RPM when starting
RE: High engine RPM when starting
what's the temp you starting the bike at? if it's super duper code, the bike will do it until the engine comes up to temp...then it'll go back down.
if it's like super duper cold, then it will do this...but 4-5 minutes is too long for it to get to operating temps...unless it's truly that cold out, in which case, i don't think you should ride.
Thanks for the fast helps. It's around 60-70 degrees at my place. However, I don't have the airducts, maybe it's the problem. Also, new problem arose. Yesterday, my bike didn't start and kept vibrating and clicking sound from the under front seat area. Any suggestion? Should I replace the battery?
