Help w/ bolt locations!
Hello,
I recently purchased an '01 CBR600F4i but it came with the fairings off and a plastic bag with a bunch of screws/bolts. I didn't have a chance to ask the seller where they all go, so I was hoping those of you on here who have some experiance with taking parts on/off the bike will be able to assist.
I have attached 3 photo's of the bolts/screws I have and tagged them all with letters so it will be easier for those of you who can help to simply say "the A bolts go..." I also know that several of the bolts are for attaching the fairings though there seems to be 4 different sizes of them and I am not sure where exactly each size goes so I've also attached a photo of a bike with the fairing bolt locations so perhaps someone can say "bolts A go to #4.."
I'm pretty sure bolts "F" are for the ends of the handlebars which have been changed. Aside from that I am not sure where the rest go... any help is greatly appreciated!!
http://i5.photobucket.com/albums/y16...O/P3250522.jpg
http://i5.photobucket.com/albums/y16...O/P3250517.jpg
http://i5.photobucket.com/albums/y16...O/P3250524.jpg
http://i5.photobucket.com/albums/y161/OsinO/a.jpg
[IMG]local://upfiles/25236/E20BBBFE752E4E3F974194EEA9EE9F5A.jpg[/IMG]
[IMG]local://upfiles/25236/F34E1E1ADBE14FC8858D49199678984D.jpg[/IMG]
[IMG]local://upfiles/25236/923C2528000746F59BB84691D921688E.jpg[/IMG]
[IMG]local://upfiles/25236/26B9EB204B584523821EAA5998E00898.jpg[/IMG]
alright, i am going to TRY and do this from memory....
A (2) bolt goes on the bottom-most hole on the fairing...it has a locating ring and is short
B (1) go on the fairing upper-most LEFT...has a locating ring and is longer than A
C (3)have a locating ring and are long...the go in the fairing below the rearsets on both sides
D - i'm not too sure of, just looks like a phillips with a washer...could go in a number of places, not knowing what is or isn't there....dunno...could go in the inner cowl between the lower fairings as those mounting holes use some typical phillips screws
E (4) are your fairing bolts for all the other places..the three by the upper fairing...the vent cowl, etc.
F are likely your bar end bolts
G and H are probably like D....
I - because they are small, (looks like from the pic)...they are likely your mirror bolts....
J - no idea...
hope that gets you started!
J - no idea...
Other than to tell you to head over and check out the Service Manual links in the stickie at the top of the General Tech section of the forum (They will show what bolts go where in the fairings in the farings section)... I won't be of much help... I CAN, however, make these pictures easier on the eyes, and require no clicking!
ORIGINAL: OsinO
