HELP!!! Turn signal issues
Old Sep 28, 2008 | 11:41 AM
billyolly's Avatar
Default HELP!!! Turn signal issues
installed hot bodies flush mount turn signal on my 06 600RR and now they don't blink, they just stay on.
Old Sep 28, 2008 | 12:31 PM
fast1000f's Avatar
Default RE: HELP!!! Turn signal issues
check your ground connections, mabye even run a new ground wire yourself if needed
Old Sep 28, 2008 | 12:43 PM
51plymouth's Avatar
Are they LED or regular bulb? LED requires a resistor in order to see the correct voltage, otherwise you get the exact problem you've described.
Old Sep 28, 2008 | 01:08 PM
redzintimidator's Avatar
not just any resistor though...i forgot what they are...load resistors maybe? They will kick out A TON of heat, so place them somewhere they will not melt anything plastic or important. You may only need one for each side, or you may need one for each signal.
Old Sep 28, 2008 | 02:38 PM
51plymouth's Avatar
ORIGINAL: redzintimidator
True dat playa. Basically it's because the LEDs have such a low ohm load, the incandescent relay sees no voltage drop and therefore does not "flash". My next question to him would be to check the specs on his new signals to determine their resistance, test his old signals w/ a multi-tester to determine their resistance, subtract one from the other and buy a load resistor with that same resistance, wire it into the positive leads and have blinky-type lights again.
Formula is this: Stock resistance-new resistance=needed load resistor
Old Sep 28, 2008 | 09:22 PM
p4eAaLcLe's Avatar
check your connections?
Old Sep 28, 2008 | 09:28 PM
D2VW14_20's Avatar
If you actually turn on your bike and let the bike run a sec then try the turns they should work, but they wont blink with the bike not running, not enough load being used. Try turning on the bike and playing with the signals a second.
warshp
Mar 11, 2015 08:35 AM
Dragondima
May 11, 2012 07:28 PM
VT2010engr
Oct 31, 2010 06:31 PM
choleaoum
Apr 9, 2010 12:40 PM
sevenhillsbilly
Aug 28, 2009 02:36 PM
