help with troubleshooting PLEASE
Old 02-18-2013 | 07:50 PM
pipe dreams's Avatar
UPDATE #3 Trying to follow the book here . I tried to start the bike ( cranked over but no fire ) pull the sparkplug and the electrode was DRY .
Im going to do a fuel flow test next .
open to any ideas please
Old 02-19-2013 | 12:11 AM
Update #4 . Okay now im lost , I did the fuel flow test and it is good . So there is enuff fuel going and coming back in the return but there is NO fuel on the spark plug .
Old 02-19-2013 | 04:07 AM
alienjoe's Avatar
Did you also try to drain a float bowl to make sure the fuel is getting into the carbs? Perhaps there is a blockage somewhere?
Sounds like something small now. One problem is fixed right? The battery doesn't immediately die on you.
It's very odd considering your first post stated that you had the bike going just fine.
Old 02-19-2013 | 06:17 AM
No carbs its fuel injected . Yes I fixed the small problem ( the battery) but why would fuel be running but not making it to the spark plugs ? My next guess is ecm not telling the injectors to open ?
I have no idea now
Old 02-19-2013 | 05:47 PM
alienjoe's Avatar
I would swap yours with a known, working ecu and at least rule it out.
Old 02-20-2013 | 11:02 AM
highwaypatrol's Avatar
Hi. Did you charge the new battery up before you installed it on your bike? I know it sounds daft, but it is best to charge it or at least check the voltage even though it is new. Might just be worth an overnight charge on a low rate?
Old 02-20-2013 | 01:22 PM
joe : I agree but I dont know where to find a good one . There $900 new .
patrol : Yes I did charge it , I kept it charged the whole time I have been working on the bike .
Old 02-20-2013 | 01:23 PM
AF4iK's Avatar
Have you checked the fuses and relays?
Old 02-20-2013 | 01:31 PM
yes i did .
UPDATE: okay i went and bought a NOID tester light and pluged it in , Tried to start the bike and it NEVER lit up ( I checked all of the injectors and nothing )
is there anything else it could be besides the ECM ?
Old 02-20-2013 | 05:12 PM
Halzinky's Avatar
Hey man my 02 F4i is doing same things
https://cbrforum.com/forum/general-t...d-help-144670/
Check that post...
My bike is currently in the shop and supposed to know in the next out or 2 whats causing the issue... As long as the mechanic doesn't take the bike till tomorrow i can let you know what fixed mine
Quick Reply: help with troubleshooting PLEASE
