Help setting Cam Timing! Does this look right?
Old May 30, 2009 | 09:06 AM
Chris07's Avatar
Default Help setting Cam Timing! Does this look right?
I have been having a hell of a time tuning my 94 CBR F2. It wasn’t the carbs, so I opened up the valve cover to check valve timing. This is what I found.
The intake seems to be a tooth off, but I am not sure how perfectly they line up. Here is a pic of the intake came on Top dead center. Does this look a tooth off to you?
Here is a pic of the exhaust cam. Perfect.
Thank for all the help!!!
Old May 30, 2009 | 06:35 PM
Todd84's Avatar
It looks off to me. The only thing to do is change it and see.
Old May 31, 2009 | 01:24 AM
justasquid's Avatar
Its odd in that it doesnt look to be off a full tooth. It looks like it is only off half a tooth. But an adjustment one tooth may be closer than what it is now.
Old May 31, 2009 | 11:07 PM
brveagle's Avatar
That's right. If you move it off a tooth, it's gonna be not level on the exhaust side. Go ahead and try it, and let us know how it turns out.
Old Jun 1, 2009 | 06:53 AM
MC_spirited's Avatar
what the he'll is with the above poster? Ban? You mods need to not let these pieces of dog**** spam our boards.
Old Jun 1, 2009 | 07:42 AM
Chris07's Avatar
I got it adjust out perfectly. Level all on both sides. Runs so much stronger now, but still have a tuning issue. It requires crazy amounts of fuel in the mid range. Also even when tuned out well my cruise state is very lean. Stumbles when cruising at 55mph in top gear. All jets are clean, so I have no clue what is going on. Think the valves might be on the tight side, but didn't have any shims to adjust while I had it open.
Old Jun 9, 2012 | 09:41 PM
phack's Avatar
New Member
Default question
when it was off a little did the engine half a spark knock. I have the same bike and i'm having the same trouble. took the head off cause i thought i had bent a valve or something was pinging. back fired some to and had carb blow back. any sound famliure or am i having other problems?
Old Jan 13, 2020 | 12:22 AM
Tfenix's Avatar
New Member
Default Need your help setting my 600rr timing
Can you please email me need some help cyrilmarrah@gmail.com
I
Old Jan 14, 2020 | 07:35 AM
Best to start a new thread of your own. This is dead thread.
CJardine
How-To: Mechanical
Oct 27, 2013 03:01 PM
coalminer frank
F2 Tech
23
Jul 16, 2012 10:30 PM
Hurricane rider
Oct 29, 2008 05:12 PM
turbojoe
Aug 26, 2006 04:44 PM
ta2av
Jan 3, 2006 07:10 PM
