help is needed
Old May 5, 2007 | 06:49 PM
barryem's Avatar
Default help is needed
i keep blowing a fuse 30 amp its the starter relay i think its connected right from the + side of the batt and then there is the relay and a fuse i put a new one in and the plug in the relay then reconnect the neg side of the batt and it pops every time what do i do what is the problem????
Old May 5, 2007 | 08:53 PM
fishfryer527's Avatar
Default RE: help is needed
Bad starter?What was the unfortunate sequence of events that led to your dilemma? Now sit down, relax and start from the beginning.
Old May 5, 2007 | 09:39 PM
barryem's Avatar
well i was driving and it just cut out it had been doing it before but i thought it was the clutch cause it happend when i was shifting down and i would go into n before i hit 1st gear so the later it just cut out and i did some trouble shotting and i found out that my fuse was blown i put a new one in and ever time i put a new one in and i blew like 10 fuses every time i put the neg batt back on it blows.
i belive it my stater relay the fuse is in the relay
here are some pics
[IMG]local://upfiles/15608/DF44B2692C5045CFB0570E049F2507F9.jpg[/IMG]
[IMG]local://upfiles/15608/0FFE396A1DD944C88EB8942F8E983CF3.jpg[/IMG]
Old May 6, 2007 | 09:21 AM
A 30 amp fuse will blow because the draw is more than 30 amps. Are you confident the starter isn't doing something it shouldn't ? other than that a simple short somewhere. There aren't many places for 30 amps to go on a bike.
Old May 6, 2007 | 12:12 PM
Quagmire's Avatar
You could either have a loose/coroded (bluish gunk that builds up on certain connections that can jump voltage from one wire to another) ground wire and it is an itermitant connection problem causing a sudden draw of volts/amps which will cause the fuse to blow. Make sure all your connections to the starter are good, clean and tight (to start with). Otherwise, it is a short circuit. There is no real easy answer to locate it. Start with one circuit/wire and check it from start to end. Look for a part of the frame or a bolt that has rubbed through the wire's insulation, causing a short.
For that particular circuit (according to the manual) the starter relay and main fuse has connections to/from the BATTERY, STARTER MOTOR, CLUTCH SWITCH, STARTER SWITCH, REGULATOR/RECTIFIER and a circuit to the diode to/from the nuetral safety switch. Good Luck and let us know what you find.
Old May 6, 2007 | 07:57 PM
barryem's Avatar
i have looked at all the wires and taped up all the ones that are cut and i still pop fuses is ther any chance my batt is over charged i charged it then got it re charged at auto zone so could that be ??
Old May 8, 2007 | 01:55 AM
barryem's Avatar
i have done some trouble shooting (some good stuff i might say) and i did some wire i jumped the relay and found out it was or so i think it is the rectifier/regulator so i will let yall know if i was right
Fubadu_the_Mighty
F3 Wanted
Jun 22, 2010 11:38 AM
jonnym61
Mar 4, 2010 01:36 PM
MattG
Aug 29, 2008 05:40 PM
stilin
Sep 20, 2005 10:19 PM
