help need to change forks
RE: help need to change forks
i would get a shop to do the work...while it is straight forward you may need some special tools (fork seal driver, etc.). learn on the side but if it's your first time, i wouldn't recommend it.
yes you need new seals...i would buy OEM ones cause they are a sure fit. as far as fork oil, check with the manual.
jfunkRR
04-30-2008 09:23 AM
