Help!! Front brakes are squishy
I have bled the front brakes 2 times now and I still have the same problem....If I am sitting at a stoplight and have the brakes on the lever will depress all the way to the hand grip, I have adjusted the dial on the brake and still no help. This will even happen while slowing down if I start from a ways back and keep on the brake the lever will come all the way to the handgrip eventually.....when I say eventually I mean in like less than 10 seconds.......any help would be greatly appreciated!!!
Sounds like either you have a loose fitting or you need either a caliper(s) rebuilt and/or a master cylinder rebuild..
it is sucking air in from somewhere..very dangerous, especially the front since all the stopping power is located there
I ordered a rebuild kit today from the local honda shop......$37 does that seem like an ok price.........I thought it was ok? Yeah I have seen what brake fluid can do to paint and plastic.........[
