help fast!!
Old 09-06-2010, 01:56 PM
greenheep's Avatar
Angry help fast!!
I have fuel coming out of a hose that isnt connected to anything?? The lines at the tank and filter are secure, no leaking there. the hose its leaking from was tucked in and running behind what looks like the water pump. it has to connect to something right??
Old 09-06-2010, 02:05 PM
motorhorse's Avatar
overflow hose most likely, did you fill up your tank too much? when it reaches the near the cap the excess goes down that hose down to the ground
Old 09-06-2010, 02:11 PM
greenheep's Avatar
would it do that if its flooded? cuz i only have like a half tank
Old 09-06-2010, 02:13 PM
greenheep's Avatar
i let the thing run for about 5 minutes and it was still coming out when i shut it off.
Old 09-06-2010, 02:29 PM
greenheep's Avatar
the hose that its coming out of is connected to that little black thing above the crank case and water pump with the big hose running to the front of the bike. still coming out
Old 09-06-2010, 03:05 PM
greenheep's Avatar
ok. The little black thing has the numbers 4x064 on it, and there's three lines. 1 big line going to the front of the bike and underneath the gauge cluster, a small line going straight down (that the fuel is leaking out of) and another big hose going up and into i think the fuel pump.
Old 09-06-2010, 03:08 PM
kilgoretrout's Avatar
Administrator - Retired
Carbed bike? Fuel injection? What bike is it?
Could be a float valve sticking and causing overflow if it's a carbed bike.
However, it should have stopped when you shut the bike off if your petcock was working (and if it's vacuum actuated and not straight piped)
Old 09-06-2010, 04:34 PM
HenryM's Avatar
Are you sure it's fuel?
I think we need a picture to be able to help you out here. Post one up Green!
Old 09-06-2010, 07:33 PM
greenheep's Avatar
ok, lemme see if these pics work....
Old 09-06-2010, 07:34 PM
greenheep's Avatar
its carbed, its a 95 cbr600f3. it does stop when i shut the bike off.
Quick Reply: help fast!!
