Help! --- Adjustable Shift Lever???
Old Dec 28, 2009 | 04:45 AM
hondamanr's Avatar
Default Help! --- Adjustable Shift Lever???
Hey guys,
I have a 98 CBR900RR and the shift lever is too low for me given the relative height of the foot peg and it is kind of a PIA to upshift (down shift is okay).
I was wondering if anyone makes an adjustable height shift lever to replace the factory one to raise it, or if I can somehow raise the factory one?
I did some research and it looks like I can get an aftermarket rear set that would accomplish this, but the one from Gilles is around $450... which is out of my budget.
Thanks in advance!
Old Dec 28, 2009 | 10:03 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Isn't the shift lever attached to a splined shaft? I would think you could remove the lever and rotate it to another position on the shaft and thus raise its position.
Old Dec 28, 2009 | 10:13 AM
letsride's Avatar
+1 you can adjust it this way.Just loosen the bolt that holds the shift lever and adjust to you liking.
Old Dec 28, 2009 | 11:22 PM
LMP1327's Avatar
wow 450. luckily they're right you should just be able to loosen the bolt and adjust it
Old Dec 29, 2009 | 11:43 AM
hondamanr's Avatar
Thanks guys, I was able to adjust it last night and it's a dream now! I can't believe how much range there is from the factory!
F3dk
Nov 1, 2009 08:41 AM
ampfp
Nov 21, 2008 12:37 AM
daking
Nov 23, 2007 05:01 PM
keemo
Sep 8, 2005 10:26 AM
