help!!! 900 lost low end power during wheelie
#21
#23
^ that would be the easiest and probably the quickest way of doing it. Otherwise, unless your confident in your ability to disassemble and reassemble the motor correctly.
otherwise swap the motor, or take it to a shop.
either way if your getting started first step would be to drop the motor.
#24
#25
or get a hack saw and a short section of pipe and make your own
#27
#29
finally got to the root of my problem..smoked a connecting rod bearing in my no.2 cylinder..almost no damage to the rest of the motor but there is a small bit of scorring on the connecting rod from the bearing spinning freely ill post pics but if its minor can some fine sanding be acceptable if done correctly to "buff"it back to operational status??or should i just look into getting a new connecting rod?
#30
