help!
Old Jun 3, 2007 | 04:35 PM
clean929's Avatar
Default help!
https://cbrforum.com/m_310080/tm.htm
Old Jun 6, 2007 | 11:30 AM
midas6t6's Avatar
Default RE: help!
Sounds like it may be a venting problem - air not getting into the fuel tank as you ride, causing fuel to flow slowly from tank. Ride it again, when the problem starts pull over. Open the gas cap for a moment, close it, and ride again. If the problem is gone, that's your problem. Clear the vent hole(s) in the gas cap and you'll be good.
