Headlights not working
Old Apr 18, 2009 | 11:10 PM
Tribal Warrior's Avatar
Default Headlights not working
Hi guys, just hoping I could get some help diagnosing my headlights. They both (normal and high beam) stopped working. I was going to check fuses but I understand there arent any for the lights. I checked superficially (ie. without taking anything apart) for any loose connections as well. I have an '05 CBR RR. thanks
TW
Old Apr 19, 2009 | 02:52 AM
pacemaker's Avatar
I don't know that much about the 05 CBR's, but They would be the only bikes that I've heard of that don't have fuses for their light's (unless they wanted small electrical fires happening in the headlight shell) So check your handbook to be sure (to be sure)
Old Apr 19, 2009 | 03:34 AM
Endless's Avatar
Siggy Maker & All Round Good Guy
I haven't the vaguest idea for the 05's
But you should head over to the new member area and introduce yourself so we can better know your backround and capabilities in order to point you in the right direction in a way you will understand.
For future notice in case you need anything else..
Old Apr 20, 2009 | 12:50 AM
rookie600rr's Avatar
Default both headlights not working
I had the same problem that happened multiple times. I could not figured what caused it. I've removed every fuse and relays but no dice.
I thought my flash-to-pass contributed to the prbolem
It fixed itself over time, just let it rest. I noticed if you use the kill switch to turn off and then turn it back on, that may help fix the problem.
Old May 7, 2009 | 12:39 PM
Any other ideas? I did get to the fuses, inspected the headlight fuse (it was ok), replaced it anyway, and still no go.
Old May 7, 2009 | 11:16 PM
509 Ghost Rider's Avatar
Had the same problem a week ago. The culprit was the starter button. There is a wire that goes to the starter button that cuts the head light power when starting, had come loose from the switch. A quick solder job and I was back on the road. And FYI, the fuse box behind the left fairing had a fuse for the headlights.
Old May 7, 2009 | 11:37 PM
speed2sound's Avatar
TW
i had a that problem 2 weeks ago on my 02 f4i it just so happen im an auto electrition so just fallow the wires from the head lights and found that my harness had burnt very odd cuz my fuse was fine so i just ran a new wire and (fused of course) and havent had a problem since
FYI fuses are to protect wires so you should realy look harder for that fuse
Old May 10, 2009 | 07:49 PM
thanks for the input guys! I did find the fuse actually and it was ok. I'll try your suggestions!
Old May 10, 2009 | 10:49 PM
bugface's Avatar
is your marker light on? try checking your right clip on like ghost rider said its got to be on the starter button.
Jarsen
Aug 12, 2010 01:12 PM
Da CbR KiD
Mar 25, 2009 12:07 PM
abelg
Dec 19, 2007 11:31 AM
02_954rr
Oct 23, 2007 10:55 AM
Rajas
May 26, 2007 02:44 AM
