head gasket
Old Sep 16, 2007 | 04:37 PM
fireblade929's Avatar
Default head gasket
im in the process of replacing the head gasket and i have a simple question. i have inspected the HG and its not broken but since its seems to have a couple layer this layers are apart around the cylinders, so is this where the water is leaking right?
Old Sep 16, 2007 | 04:49 PM
pacemaker's Avatar
Default RE: head gasket
Yep, they don't break, but "Blow" between the layers, I know it will cost you a few bucks, but you should have head checked for warpage before you go putting a new gasket on, its something that you can't see by looking at it. It will save you some grief later on, cos if it is warped, it will blow in the same place again. if warped, it can be fixed, no wukkin furries.
Old Sep 16, 2007 | 04:53 PM
can i do the warp check myself? i've heard that is easy to do with a level and a feeler gauge or should i just take it to the shop?
Fryup2000
Aug 6, 2013 05:43 PM
bwp777
Aug 7, 2007 12:51 AM
mikeyvis
Jan 17, 2007 06:13 PM
dirtysouthjacket
Mar 6, 2006 03:51 AM
