Having problems on cbr600f 02 fuel injection
Old Mar 7, 2011 | 01:26 PM
Ultomo's Avatar
Registered Users
Default Having problems on cbr600f 02 fuel injection
Hi, lately when I've been riding my bike ( cbr600f 2002) I've been loosing power when accelerating, the FI light comes on and I loose power. Sometimes it cut out all together but most the time it cuts back in. Would this be a problem with the fuel filter? Or the whole file injection pump? Any ideas?
Old Mar 7, 2011 | 05:56 PM
justasquid's Avatar
My first thought would be to get the codes from the bike since the FI came one.
Having said that, those models have been known to have fuel pressure regulator issues. You can physically check the FPR by removing the vacuum line on it and see if there is gas in it. If gas is present, the FPR is bad.
has your fuel mileage been bad?
A little more description of the bikes past may help too. Such as mileage, ever been layed down, modifications....ect.
Old Mar 8, 2011 | 07:40 PM
iJapanesey's Avatar
Reset ur ECU and give us the # of blinks. Sounds like u may have a bad MAP sensor or loose vacuum hose/s. That will cause ur ECU to tell the fuel pump to deliver a jacked up amount of fuel. Been there, done that.
Old Mar 9, 2011 | 05:41 AM
Slick 6's Avatar
Hey check my post Baffling FPR, theres some steps you could take to check the fpr.
Mine wasn't cutting out but to eliminate or be sure about it, follow them. pretty easy to do.
Arthur48
Apr 25, 2015 01:47 PM
600ninja
Apr 9, 2010 04:54 PM
user 723923
Jul 2, 2007 06:24 PM
koelzer18
Mar 24, 2006 05:51 PM
