Having fun.. WIN A 6-PACK OF ANYTHING!
Making a mess.. still cant figure out how to get the bank angle sensor to start so my damn bike will run!
If anyone can show me a simple picture of how to "rig" or "jump" the bank angle sensor i will UPS a 6-pack of any type of beer to their door step! PROMISE lol
![](http://i656.photobucket.com/albums/uu281/ergophobic11/11111.jpg)
it should be pretty easy. I have added a couple of photos and added text to them. Hopefully it helps.
Just fot ****sngrins though..... turn you key on, the rotate your headlights side to side, and upsidedown... see if you hear the fuel pump kick on at all. the bas may just be stuck or if it was damaged, it could have lost its oil and the blade is stuck away from the contacts inside.
heres the pics... you can try to use a paper clip with the bas still hooked up, just slide the paper clip behind along the wires and into the plug. Or, disconnect the bas and jump those same two wires on the plug from the harness.
