God I feel stupid asking this. ><
if you dont feel confident riding it, look for a bit of a hill. Sit on the bike and pull the clutch in. Roll yourself down the hill and keep pressure on the shift lever. You should feel it pop down a gear, just keep doing that until you cant do down anymore. You should be able to roll it back and forth with the clutch pulled in and click down the gears. Bikes tend to get stuck in gear sometimes if you do what you did.
Also, if you are at a stop light and put it in neutral you may have to do the rocking method to get back in gear. NEVER put your bike in neutral while at a light. Especially when you are the only one at the light. Especially as a new rider. If you are at the front of a pack of cars at the light and you have many behind you that are stopped, and you feel you need to strech then put it in neutral. Just make sure to pay attention and always get back in gear before the lights change.
I would also suggest some sort of Motorcycle safety course to help you figure out the whole riding thing, or at least some instruction by an experienced rider.
Not sure where you are from but this is a link to the MSF site which runs courses here in the U.S. they will help you learn the basics, on their bike allowing you to learn without putting your new pride and joy at risk.
http://www.msf-usa.org/
this reminds me, when i first got my bike i thought that neut was all the way down. That is, when i put it into neut i thought that was as low as the shifter would go. (I didnt try to go any further) I continued on this way using second as my first until figured out i should have more power in my "first" gear.
You do know that neut is all the way down and one up right?
(In case the hand method didnt click.)
Don't get to anxious about taking her out and throwing miles on. Start small work your way up.
I second the MSF.
I second the MSF.
Guest
Posts: n/a
Ok.
Tried riding the bike, great first ride! Couldn't get moving!
Hehe, although it was informative.
I foud out that I'm obviously not stuck in first since it just stalls as soon as I let out the clutch - tried multiple ways. No revs, some revs, a good amount. I think I got it up to 6k revs letting it out, I didn't want to go any higher incase it took off without me. >< Lol.
Anyway, on top of that I found I can only shift up two gears and back down those same two.
My guess from a little reading is that the chain is probably stuck in a wrong place, or needs adjusting. Maybe even something with the clutch cable.
So I'm going to call the dealer on Monday to see what can be done, but if you guys have any ideas I'd love those.
I'm itching beyond belief to ride. Lol.
Thanks again in advance.
but...
It just sounds like you are in a high gear ...they won't go anywhere in say 4th gear ...not if you rev them off the clock (btw-dont do that!!)
If you just start it ..
Sit on the bloody thing ...click the gear **** down down down ..over and over gently while rocking the bike forward and back , she might just select the lower gears ..
Question....have you seen the neutral(green) light com on at all ??
that is a clue as to if you are close to first LOL...
and om not laughing at you mate ...om just having a chuckle
If you are worried or can't figure it out ....do you know any riders with some experience close by ..? down your street or a neighbor even ?
I hate to hear that she is driving you nuts mate ... and I hope you sort it out , but as you said a dealer may be your answer, if you have no one else with experience close by...
good luck
Ok.
I'll give her a go walking her forward and rocking a little, it really sounds like I just made a rookie mistake by trying to change with the motor off. :P
For reference, yeah, I've seen the neutral light on. It was on every time I flicked the iginition to on until I tried changing gears.
And also - Thanks to the guy with the finger method! I also thought neutral was just as far down as the shifter would go, but I understand what you mean now about it being between first and second. :P
Will post back with the results - If it doesn't work I'm going to call the dealer.
It shouldn't be anything serious, at least, I hope not. >:
Thanks all for your help!
Ok. Well I tried rocking it and it's solved the gear sticking issue.
I can now successfully shift all 6 gears up and down.
The bike still doesn't seem to want to hit Neutral though, which is probably just my inexperience shifting the gears.
Does anyone have any tips or tricks of how to find it?
Thanks again guys!
Thanks again guys!
Gotta be 18 and have had a car license (at what's called P2 level, basically an open license but with power restrictions) to even get a bike learners.
And to ride I've gotta be being followed (or have on the pillion) someone whose held an open bike license for 5 years.
We also have a thing called Q-Ride that I'll be doing. It's basically a how to ride course, so yeah. ~.<
Ah-ha! I got it!
Turns out I got some wrong advice.
I was pressing the shifter down thinking that was up gear. So, pretty much I was starting in 6th thinking that was 1st.
Found out I was wrong, and I've got it in Neutral again and I'm stoked.
Now I can start riding! And hopefully not dying!
Thanks guys!
Thanks guys!
Sounds good. Have fun and be careful.
One of your first stops should be the riding gear shop. (that is if you have the mula)
Check this place out. Alpinestars
