gear shifting twice sound!
hi..
when i shift from 2nd gear to 3rd gear specifically..i can hear the sound twice on the lever for gear shifting.i mean..i can feel that i hear 'thump' 'thump' twice. is it because i shift the gears slowly? i feel something happening twice! is it normal? i mean..when i start off at a rage, i dont feel the lever making the sound twice coz at probably i shift very fast..but on normal pace, i feel the lever engaging twice before resting..please note the gears shift properly, no problems there, ..i just wanted to know if this is normal in all bikes..thanx.
ameer.
ameer.
i think i have to try all the options above and see what i am doing wrong..mmm....i wont be shifting the gears from 2nd to 4th coz i kinda count the gears when i shift.so i cant be doing that...mmm..not letting go of the clutch, maybe thats what i am doing.lemme check and will get back to u..thanx guys.
ameer.
ameer.
mm..you are rite about sitting on a normal bike later on can feel a little odd but anyways..let me try out the other options,i may have developed some bad habits while shifting wrongly which makes this sound or a feeling of two clicks! mmm...strange very strange...
ameer.
ameer.
Just something to look at, but it may sound dumb but is your chain tightened to the correct tennsion, if a chain is to loose you will get the thump of the trainy and then when you take up the slack in the chain you will get a sencond thump. but your chain will have to be loose as h$ll.
RocketJocky
07-24-2008 10:37 AM
