gauge cluster problems
Old Mar 30, 2011 | 08:20 AM
Rhinocbr's Avatar
Default gauge cluster problems
01 600f4i
my temp will read 95 and then jump up to what i expect is the right temp. after 5-10 min it will go back down to 95. sometimes it will read -- when i know its warmed up enuff. also my trip counter and clock reset sometimes when i shut the bike off.
loose connection?
Old Mar 30, 2011 | 02:34 PM
Most likely a loose connection. The Thermo-Sensor on the bike is basically a variable resistor that changes resistance with temperature. Your temp gauge simply reads a voltage based on that sensor. A loose connection can easliy cause strange readings.
Old Aug 31, 2011 | 01:13 AM
flyinhgher's Avatar
mine does the same thing. I even took it in after i changed the sensor. they said it was my cluster. i still bounce around and end up on --. I plan on ripping it all apart this winter
deputydelicious
Jun 15, 2013 07:09 AM
