Gauge Cluster Blank
06 CBR 600 RR
Went for a quick ride today running a few errands everything working fine. When I pulled into driveway I realized the gauge cluster was blank. The time is still displayed correct and the second : is still blinking keeping time. Any ideas what could cause this and where should I check to see if a wire is loose or something? Any help is appreciated.
Thanks
Thanks
+1 on the fuse. Earlier in the summer the same thing happened to me. Went for a quick ride and noticed that i had no display. All that was working was Turn Signals, Clock, and High Beam Indicator. Pulled off to the side of the road and check my fuses. Sure enough a Red 10 AMP fuse was blown. Replaced the fuse and everything was back to normal.
fuse. Happened to me...actually, I had2 factory fuses blow in the first 1000 miles (guages and headlights), the ones replaced haven't blown since (3 years, 14,000 miles).
